whitepau_altera
Contributor
1 year agoThe "Report has invalid data. Ok to proceed?" error is unrelated to the bandwidth notes you are seeing; this is a known defect in the reports that you may ignore.
The incorrect Global Memory Bandwidth estimates might be an issue with your BSP; does the board_spec.xml that you got from Terasic have any value specified for Global Memory Bandwidth?
Björne2
1 year agoI think so. /vol/opt/intelFPGA_pro/21.2/hld/board/de10_agilex/hardware/B2E2_8GBx4/board_spec.xml contains:
<!-- DDR4-2666 --> <global_mem name="DDR" max_bandwidth="85312" interleaved_bytes="1024" config_addr="0x018"> <interface name="board" port="kernel_mem0" type="slave" width="512" maxburst="16" address="0x00000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> <interface name="board" port="kernel_mem1" type="slave" width="512" maxburst="16" address="0x200000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> <interface name="board" port="kernel_mem2" type="slave" width="512" maxburst="16" address="0x400000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> <interface name="board" port="kernel_mem3" type="slave" width="512" maxburst="16" address="0x600000000" size="0x200000000" latency="240" waitrequest_allowance="6"/> </global_mem>
Moreover, if I compile an equivalent OpenCL kernel (aoc -bsp-flow=flat -rtl vector_add.cl) global memory bandwidth is estimated correctly (see screenshot).
