student1
5 years agoAcceleration stack
If I want to use intel PAC cards with oneAPI DPC++,should I also install the Acceleration stack software?
Thank you.
JohnT_Altera
5 years agoHi,
If you would like to use the BMC and update the board then it is recommended to install the accelleration stack. If you are only testing the OneAPI then you do not need to install it. You may refer to https://software.intel.com/content/www/us/en/develop/documentation/installation-guide-for-intel-oneapi-toolkits-linux/top/installation/set-up-a-system-for-fpga-with-the-intel-pac/install-intel-fpga-add-on-for-oneapi-base-toolkit-package.html for how to setup the FPGA for OneAPI.
