About Al Tensor Block design
- 6 years ago
Hi Ryoji,
Thanks for your update. Sorry as I am not really familiar with low level logic design and thus could not really comment on your circuitry. Sorry for the inconvenience.
Hi Ryoji,
Thanks for your update. For your information, I do not have much visibility into the semicon materials and thus I could not provide further comment on this. Regarding the design, generally we are referring FPGA design ie HDL coding. If you would like to check if your HDL design can be implemented using a specific FPGA, you could use the Quartus Prime software and run through compilation to verify that.
Regarding the licensing management, sorry as I do not have visibility into it and could not really comment further. Generally we would address licensing inquiries related to FPGA software and IP in this forum. Sorry for the inconvenience.
Chee Pin
- Ryoji6 years ago
Dear Chee Pin,
I drew an AND circuit with a transistor. Only if both inputs A and B create enough voltage and current to switch the transistor on, the output will be 1. Could this be a new type of AND circuit? Moreover, I think it is how AND logic applied to a quantum logic gate, as explained in the paper. I wonder if we can implement it to FGPA directly? Or do we need another layer of a semiconductor like GaN on Silicon FGPA board?
Thank you,
Ryoji
