ZXued
6 years agoAbout 10bitsPerSymbol of ihc::stream_out
I want to use ihc::stream with 10bitsPerSymbol parameter, I defined a interface using: typedef ihc::stream_out<ac_int<120, false>, ihc::buffer<2>, ihc::readyLatency<1>, ihc::usesPackets<true>, ihc:...
AnilErinch_A_Intel
6 years agoHi ,
Can you try with different ac_int values and lets know , whether the compilation gets successful , when the result is divisible by 10 .
Thanks and Regards
Anil
- whitepau_altera6 years ago
Contributor
Hi @ZXued
There is currently a restriction on `ihc::bitsPerSymbol` such that symbol widths must be a power of 2. This is a known issue.
