AnilErinch_A_Intel
6 years agoHi ,
As per the compiler pro documentation
ihc::buffer can be used only with the input stream,
Please refer to the compiler pro documentation
https://www.intel.com/content/www/us/en/programmable/documentation/ewa1462824960255.html
for each of the options in the code given and let us know the results.
Thanks and Regards
Anil
ZXued
6 years agoThanks for you replay, I remove ihc::buffer on output stream but the problem isn't been solved. I think the result of express "sizeof(ac_int<120, false>)" is not divisible by 10
