5G LDPC Transmitter and Receiver Test Cases
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Can I get a positive response for the below mentioned post which I have posted before.
Thanks for the response. But actually what I wanted to test was the LDPC testcases for throughput with variable base-graph(BG) and code rate(k/n). Right-now the command which you provide is about running same test case multiple times and gets the throughput(ie. as per my understanding).
Please guide me through how can I change the BG and coderate and verify the throughput as per attached image.
Also I wanted to take out the FEC processed data from PAC card to external device directly through the the ethernet ports available on card. How can I do it?
Thanks in advance,
Mable George
