MABLE
3 years ago5G LDPC Transmitter and Receiver Test Cases
How to run test cases of 5G LDPC transmit/receive test cases mentioned in an907 document.
As of now I have done l1 and testmac in FlexRAN 22.03 using PAC N3000 card as per an912 d...
MABLE
3 years agoHi,
Thanks for the response. But actually what I wanted to test was the LDPC testcases for throughput with variable base-graph(BG) and code rate(k/n). Right-now the command which you provide is about running same test case multiple times and gets the throughput(ie. as per my understanding).
Please guide me through how can I change the BG and coderate and verify the throughput as per attached image.
Also I wanted to take out the FEC processed data from PAC card to external device directly through the the ethernet ports available on card. How can I do it?
Thanks in advance,
Mable George
