User1582192733150209
6 years ago./pac_hssi_e10: error while loading shared libraries: fpga_hssi.so: cannot open shared object file: No such file or directory when I was following the 10Gbps Ethernet Accelerator Functional Unit Design Example user guide
Dear Sir/Madam, I am having a software error issue when I was running the example based on the 10Gbps Ethernet Accelerator Functional Unit Design Example user guide. error was this ./pac_hssi_e10...
JohnT_Altera
6 years agoHi,
There is some issue on excuting "export LD_LIBRARY_PATH='pwd':$LD_LIBRARY_PATH" which the current directory is not added into the environment. Please use "export LD_LIBRARY_PATH=$(pwd):$LD_LIBRARY_PATH" which will fixed the issue.
