critical
602 TopicsWhy does the Intel® FPGA Download Cables drivers installation fail on Windows* operating system?
Description Due to the expiration of the digital signature certificate of the Intel® FPGA Download Cable I (formerly referred to as USB Blaster I download cable) and the Intel® FPGA Download Cable II (formerly referred to as USB Blaster II download cable) drivers for Windows* operating system, the installation process of the drivers may fail. Follow the next steps to verify if the digital signature certificate of your driver has expired: Go to '<Quartus Installation Path>\qprogrammer\quartus\drivers\usb-blaster-ii' folder Right-click on 'usbblasterii.cat' and select 'Properties, then select the 'Digital Signatures' tab Select the 'IFDLII Production Key1' signature from the 'Signature List' and click 'Details' Click on 'View Certificate' If the driver has expired, you will see the 'This certificate has expired or is not yet valid' message Resolution A patch is available to fix this problem for the Intel® Quartus® Prime Software. Download and install Patch 0.02i for the Intel® Quartus® Prime Pro Edition Software version 20.4 and the Intel® Quartus® Prime Standard Edition Software version 21.1. Download and install Patch 0.02i for the Intel® Quartus® Prime Pro Edition Programmer and Tools or Patch 0.02stdp for the Intel® Quartus® Prime Standard Edition Programmer and Tools from the appropriate link below. Download Intel® Quartus® Prime Pro Edition Software version 20.4 patch 0.02i for Windows (.exe) Download the Readme for Intel® Quartus® Prime Pro Edition Software version 20.4 patch 0.02i (.txt) Download Intel® Quartus® Prime Standard Edition Software version 21.1patch 0.02stdp for Windows (.exe) Download the Readme for Intel® Quartus® Prime Standard Edition Software version 21.1 patch 0.02stdp (.txt) After installing patch 0.02i or patch 0.02stdp for Windows, follow the next steps to update the driver on the operating system: Connect your Intel FPGA download cable or Intel FPGA download cable II Open Device Manager window of Windows* OS Choose Windows Settings from Start menu > Type “Device Manager” into the search area > Choose Device Manager Find Altera USB-Blaster II under JTAG cables or Altera USB-Blaster under Universal Serial Bus controllers Find USB-Blaster or USB-Blaster II under Other devices Choose Altera USB-Blaster or Altera USB-Blaster II Right-click and choose Update driver from the context menu Choose Browse my computer for driver software on the Update Drivers window Enter the following path for the driver and enable; include subfolders - <Intel Quartus Prime software install directory>\quartus\drivers or - <Intel Quartus Prime Programmer install directory>\qprogrammer\drivers or - <Intel Quartus Prime Programmer install directory>\qprogrammer\quartus\drivers Click Next This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.1.3KViews0likes0CommentsWhy are Non-Fatal PCIe* errors logged in Advanced Error Reporting (AER) when using the Intel® FPGA P-Tile/H-Tile , Avalon® Streaming and Avalon® Memory Mapped IP for PCI Express*?
Description The P-Tile/H-Tile Avalon® Streaming Intel® FPGA IP for PCI Express* and the P-Tile/H-Tile Avalon® Memory Mapped Intel® FPGA IP for PCI Express* implements optional Alternative Routing-ID Interpretation (ARI) capability when Multi-function or Single Root I/O Virtualization (SR-IOV) features are enabled. ARI capability includes a field called next function number to help the host BIOS to perform the enumeration process. When ARI is enabled and the number of Physical Functions (PFs) is less than 8 for P-Tile, or 4 for H-tile, the next function number incorrectly shows a value of PF 1. As a result, the following error status bits in the endpoint may get set if AER is enabled, as the Root Port issues a configuration request to the non-existing PF pointed to by the incorrect next function number: Correctable Error Detected (Device Status Register) Unsupported Request Detect (Device Status Register) Advisory Non-Fatal Error Status (Correctable Error Status Register) Unsupported Request Error Status (Uncorrectable Error Status Register) Only set if Advisory Non-Fatal Error Mask bit is set to ‘0’ (Correctable Error Mask Register) An ERR_COR message will be sent to the Root Port if AER is enabled by setting the following bits below: Advisory Non-Fatal Error Mask is set to '0' (Correctable Error Mask Register) Correctable Error Reporting Enable is set to '1' (Device Control Register) Unsupported Request Reporting Enable is set to '1' (Device Control Register) In the Root Port, the following bit will be set if Completion with Unsupported Request status is received Received Master Abort (Secondary Status Register) Also, in the Root Port, the following bit will be set if ERR_COR is received, and AER is enabled ERR_COR Received (Root Error Status Register) Resolution For the P-Tile/H-Tile Avalon® Streaming Intel® FPGA IP for PCI Express* and For the P-Tile/H-Tile Avalon® Memory Mapped Intel® FPGA IP for PCI Express*, software can ignore the detected errors each time enumeration is done. If the following error status bits are set in the endpoint after enumeration, then it is safe for the software to ignore them: Correctable Error Detected (Device Status Register) Unsupported Request Detect (Device Status Register) Advisory Non-Fatal Error Status (Correctable Error Status Register) Unsupported Request Error Status (Uncorrectable Error Status Register) Only if Advisory Non-Fatal Error Mask bit (Correctable Error Mask Register) is set to ‘0’ For simplicity, the workaround can be done in the following order Upon enumeration complete, clear the error registers below (all bits irrespectively) for all PCIe Endpoint Functions Device Status Register Correctable Error Status Register Uncorrectable Error Status Register Clear the error registers below (all bits irrespectively) for the PCIe Root Port related to the PCIe Endpoint Functions above Secondary Status Register Root Error Status Register Repeat step 1 and step 2 for each PCI enumeration process. If runtime polling for errors is being performed, bits 'Correctable Error Detected', 'Unsupported Request Detect', 'Advisory Non-Fatal Error Status' and 'Unsupported Request Error Status' can be checked by the polling software to differentiate this issue from other reliability errors. If only those 4 bits are set, we can assume the errors on the endpoints are related to the P-Tile/H-Tile Avalon® Streaming Intel® FPGA IP for PCI Express* or the P-Tile/H-Tile Avalon® Memory Mapped Intel® FPGA IP for PCI Express* issue and it is appropriate to proceed to clear the error status bits listed in step 1 and step 2 above. For P-Tile, user logic can use the Configuration Intercept Interface (CII) to correctly advertise the ARI next function number when a Configuration Read is issued by the Root Port.1.4KViews0likes0CommentsIs the Nios® II Software Build Tools (SBT) for Eclipse included in the full installation of the Intel® Quartus® Prime Pro Edition Software starting from version 19.1?
Description No, the Nios® II SBT for Eclipse is not included starting from Intel® Quartus® Prime Pro and Standard Edition Software version 19.1 onwards. Resolution To install the Nios® II SBT for Eclipse, follow the steps below: 1. Download CDT 8.8.1 which is Eclipse C/C IDE for Mars.2 CDT 8.8.1 for Windows CDT 8.8.1 for Linux Note: Try the mirror links if the main source link doesn't work. 2. Extract the downloaded file into <Intel Quartus installation directory>/nios2eds/bin. You should see the <Intel Quartus installation directory>/nios2eds/bin/eclipse folder after extraction is done. 3. Rename the <Intel Quartus installation directory>/nios2eds/bin/eclipse folder to <Intel Quartus installation directory>/nios2eds/bin/eclipse_nios2 4. Extract the <Intel Quartus installation directory>/nios2eds/bin/eclipse_nios2_plugins.zip (or tar.gz for Linux) to <Intel Quartus installation directory>/nios2eds/bin. The extraction will override files in <Intel Quartus installation directory>/nios2eds/bin/eclipse_nios2. 5. Verify the extraction is done correctly by making sure you see the <Intel Quartus installation directory>/nios2eds/bin/eclipse_nios2/plugin_customization.ini file 6. You can now launch Nios II SBT for Eclipse via eclipse-nios2.exe The instructions are included in the <Intel Quartus installation directory>/nios2eds/bin/README. This information will be included in the future release version of Intel® FPGA Software Installation and Licensing User Guide.999Views0likes0CommentsWhy does the Quartus® Prime Pro Edition Programmer program pof file to DK-DEV-AGI027RBES unsuccessfully when following the R-Tile FPGA IP for Compute Express Link* (CXL*) Design Example User Guide?
Description Due to a problem in the R-Tile FPGA IP for Compute Express Link* (CXL*) Design Example User Guide, version 1.10.0, you might observe pof programming failure on DK-DEV-AGI027RBES when following the chapter "C. Programming the Agilex™ 7 FPGA Development Kit with an External USB Blaster II", the description for the programming steps of DK-DEV-AGI027R1BES and DK-DEV-AGI027RBES is not separate and clear enough. Resolution To work around this problem, refer to the following instructions: 1. The programming steps for DK-DEV-AGI027R1BES: Connect an external USB blaster II into the J10- External JTAG header. Set the switch SW5.3 to ON (for the first time). Open the Quartus® Prime Pro Edition Software programmer tool. Click the Hardware Setup, and select USB Blaster II. Set the Hardware Frequency to 16000000Hz and uncheck the Auto-adjust frequency at chain scanning box. Click Close. Click Auto Detect and select MAX® 10 device, click OK. Right-click on the MAX® 10 device, and select Edit -> Change File. Select the MAX® 10 SOF file image: max10_bmc_avstx8_test.sof and click Open. Check the Program/Configure box and click Start to start the programming operation. When the operation is 100% successfully completed, click Auto Detect. Click Yes on pop-up windows. Right click on the QSPI_2Gb device, select Edit -> Change File. Select the POF file image: file.pof and click Open. Check Program/Configure box of QSPI_2Gb, P1, OPTION_BITS and click Start to start the programming operation. When the operation is 100% successfully completed, close the programmer window, shut down the platform (Pressing the on-off button on your server instead of typing “poweroff” in command window), set SW5.3 to OFF, disconnect USB Blaster II and boot the platform again. Type “lspci -vt ” in the command window, 0ddb device should be found. 2. The programming steps for DK-DEV-AGI027RBES: Plug in the USB cable to the USB port J8 (when using J10, DIPSWITCH SW5.3 (DK-DEV-AGI027RES and DK-DEV-AGI027R1BES) and SW8.3 (DK-DEV-AGI027RB and DK-DEV-AGI027-RA) should be off). Set the DIPSWITCH SW2 to [on:off:off:X] (the 4th bit is don't care). You can follow this combination which has been verified on the hardware: SW1=ON/Off/Off/Off; SW2=ON/Off/Off/Off; SW3=Off/ON/ON/Off; SW4=Off/Off/ON/Off; SW5=Off/Off/Off/Off; SW8=Off/Off/Off/Off Open the Quartus® Prime Pro Edition Software programmer tool. Click the Hardware Setup, and select USB Blaster II. Set the Hardware Frequency to 16000000Hz and uncheck the Auto-adjust frequency at chain scanning box. Click Close. Click Auto Detect to scan the JTAG devices. If the JTAG chain can not be detected, try setting SW4:3 to OFF. If a device called 1_BIT_TAP appears between AGIB027R29AR0 and VTAP10, ignore it and continue to the next step. Right click the VTAP10 device, Edit > Change Device, change it to MAX 10 > 10M50DAF256. Right click the 10M50DAF256 device, Edit > Attach Flash Device, select Quad SPI Flash Memory QSPI_2Gb. In the Programmer page, click QSPI_2Gb > Change File to select the .pof file. Start the Programmer. When the operation is 100% successfully completed, close the programmer window, and shut down the platform (Pressing the on-off button on your server instead of typing “poweroff” in the command window), if SW4:3 was OFF before, set it to ON, disconnect USB Blaster II and boot the platform again. Type “lspci -vt ” in the command window, 0ddb device should be found.700Views1like0CommentsDesign files with lengthy file paths might cause an internal error in the Windows version of the Quartus Prime Pro Edition software
Description Because of the hierarchical manner in which the Quartus Prime Pro Edition software organizes the design database files, an internal error might occur in the Windows version of the Quartus Prime Pro Edition software when the file path to a design file is too long. Resolution Windows has a 260-character limit on the combined length of a file name and its file path. To reduce the length of a file path to a design file, avoid storing your Quartus Prime project in a directory that is far removed from the drive location.699Views0likes0CommentsWhy does Stratix 10 SoC fail to complete JIC flash file programming when using combined FPGA and HPS JTAG?
Description In the Intel® Quartus® Prime Pro software version 18.0, the Quartus Prime Programmer tool may crash when attempting to perform JIC file programming, if the Intel Stratix® 10 SoC device is already configured with the combined FPGA and HPS JTAG option. This is because the FPGA is initially the second device in the JTAG chain (after the HPS) - however once the SFL helper image is programmed, the HPS is removed and the FPGA is now the first device in the JTAG chain. The discrepancy in JTAG device numbering causes the Quartus Programmer tool to crash as it is expecting the FPGA device to remain at the same location in the JTAG chain during the entire process. This issue does not impact you if: The Intel® Stratix® 10 SoC device remains unconfigured before the start of JIC file programming The Intel Stratix 10 SoC HPS JTAG is using the HPS dedicated I/O pins and does not share the same JTAG chain with FPGA. Resolution Use one of the following workarounds in order to perform flash programming on the board: Power up the board with MSEL[2:0] set to 111 (JTAG). In this way, the device will remain unconfigured prior to JIC file programming, and the JTAG chain will contain only one device (FPGA). Once the Quartus Prime Programmer tool has completed the JIC file programming, you can set the MSEL[2:0] back to 100 in order for the device to boot automatically from QSPI on the next power cycle. Externally pull nCONFIG to low when powering up the board to prevent device from configuring using QSPI. Initiate JIC programming using JTAG - once SFL helper image have been programmed, you can release the nCONFIG pin. Use the software running in the HPS (for example, U-boot) to program the QSPI device. This method uses the Raw Programming Data (.rpd) file format instead of a JIC file. Refer to the Intel Stratix 10 Configuration User Guide for steps to generate the .rpd programming file. This problem will be fixed in future version of the Intel Quartus Prime Pro software.600Views0likes0CommentsWhy does the Deinterlacer II IP core GUI erroneously create a deinterlacer IP with no I/O ports?
Description Due to a problem with the v16.1.2 version of the Deinterlacer II® IP, the GUI will erroneously create a deinterlacer with no I/O if motion adaptive mode is selected without cadence detection and reverse pulldown, but with 3:2 & 2:2 detector with video over film still showing as a grayed-out cadence detection algorithm selection. Resolution To work around this issue in v16.1.2, enable cadence detection and select one of the other cadence detection modes. This problem has been fixed starting in software version 17.0.599Views0likes0CommentsWhy does the Synopsys VCS* simulator produce incorrect simulation results for Agilex® 5 FPGAs?
Description The Agilex™ 5 FPGAs do not support the Synopsys VCS* two-step flow (compile and elaborate in one step and simulate in the next). You might see incorrect simulation results when simulating a multi-IP design with Synopsys VCS* simulator if you specify all IP and Quartus® simulation library source files using a single VCS command line, run_vcs. Resolution Follow these steps to use Synopsys VCS* simulator with VCS MX flow: Create design libraries using the mkdir command Compile all IP and Quartus® simulation library source files into their respective libraries using vlogan or vhdlan commands Elaborate the top-level design using the vcs command without specifying the source files compiled in Step 2 Simulate your design using the generated simv executable file The above steps are sometimes called VCS or VCS MX three-step flow (compile in one step, elaborate in the next step, and simulate in the final step). For information on which library files to be compiled, command examples, and command arguments, refer to the Platform Designer-generated VCS MX simulation setup script (/synopsis/vcsmx/vcsmx_setup. sh). If you were previously using the Platform Designer-generated VCS simulation setup script (/synopsys/vcs/vcs_setup.sh), switch to using the Platform Designer-generated VCS MX simulation setup script (/synopsys/vcsmx/vcsmx_setup.sh). Refer to Quartus® Prime Pro Edition User Guide: Third-party Simulation for more guidelines on incorporating the generated Synopsys VCS MX simulation scripts into a top-level project simulation setup script. Agilex® 5 FPGA no longer supports the VCS 2-step flow; only the VCS 3-step flow is supported.500Views0likes0CommentsWhat is the latest device firmware for the Agilex® FPGA and Stratix®10 FPGAs?
Description Altera® recommends using the latest version of the Quartus® Prime Pro Edition Software and the latest available device firmware. Please also see the following user guides: Updating the SDM Firmware in the Agilex® 7 FPGA Configuration User Guide Updating the SDM Firmware in the Stratix® 10 FPGA Configuration User Guide Resolution The latest device firmware available for the Quartus® Prime Pro Edition Software can be downloaded from the following links: Quartus Prime Pro Edition Software version 25.3 What is the latest device firmware for the Quartus® Prime Pro Edition Software version 25.3? Quartus Prime Pro Edition Software version 25.1 What is the latest device firmware for the Quartus® Prime Pro Edition Software version 25.1? Quartus Prime Pro Edition Software version 24.3.1 What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.3.1? Quartus Prime Pro Edition Software version 24.3 What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.3? Quartus Prime Pro Edition Software version 24.2 What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.2? Quartus Prime Pro Edition Software version 24.1 What is the latest device firmware for the Quartus® Prime Pro Edition Software version 24.1? Quartus Prime Pro Edition Software version 23.4 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 23.4? Quartus Prime Pro Edition Software version 23.3 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 23.3? Quartus Prime Pro Edition Software version 23.2 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 23.2? Quartus Prime Pro Edition Software version 23.1 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 23.1? Quartus Prime Pro Edition Software version 22.4 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 22.4? Quartus Prime Pro Edition Software version 22.3 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 22.3? Quartus Prime Pro Edition Software version 22.2 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 22.2? Quartus Prime Pro Edition Software version 22.1 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 22.1? Quartus Prime Pro Edition Software version 21.4 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 21.4? Quartus Prime Pro Edition Software version 21.3 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 21.3? Quartus Prime Pro Edition Software version 21.2 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 21.2? Quartus Prime Pro Edition Software version 21.1 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 21.1? Quartus Prime Pro Edition Software version 20.3 What is the latest device firmware available for the Quartus® Prime Pro Edition Software version 20.3?500Views0likes0CommentsError(13224): Verilog HDL or VHDL error at altera_pcie_s10_hptxs_tx.sv(<your line number>): index <your index> is out of range [<your range>] for address
Description Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 17.1 and earlier, you will see this error with the Avalon®-MM Stratix® 10 Hard IP for PCI Express* if you do the following: Select "Enable high-performance bursting Avalon-MM slave interface (HPTXS)" And select "Enable mapping (HPTXS)" AND select one of the first two choices 1 page - 0 bits 2 pages - 1 bit Resolution To work around this issue, choose one of the remaining 8-page mapping selections. This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 17.1.1.499Views0likes0Comments
