Knowledge Base Article
Why does the Synopsys VCS* simulator produce incorrect simulation results for Agilex® 5 FPGAs?
Description
The Agilex™ 5 FPGAs do not support the Synopsys VCS* two-step flow (compile and elaborate in one step and simulate in the next). You might see incorrect simulation results when simulating a multi-IP design with Synopsys VCS* simulator if you specify all IP and Quartus® simulation library source files using a single VCS command line, run_vcs.
Resolution
Follow these steps to use Synopsys VCS* simulator with VCS MX flow:
- Create design libraries using the mkdir command
- Compile all IP and Quartus® simulation library source files into their respective libraries using vlogan or vhdlan commands
- Elaborate the top-level design using the vcs command without specifying the source files compiled in Step 2
- Simulate your design using the generated simv executable file
The above steps are sometimes called VCS or VCS MX three-step flow (compile in one step, elaborate in the next step, and simulate in the final step).
For information on which library files to be compiled, command examples, and command arguments, refer to the Platform Designer-generated VCS MX simulation setup script (/synopsis/vcsmx/vcsmx_setup. sh).
If you were previously using the Platform Designer-generated VCS simulation setup script (/synopsys/vcs/vcs_setup.sh), switch to using the Platform Designer-generated VCS MX simulation setup script (/synopsys/vcsmx/vcsmx_setup.sh).
Refer to Quartus® Prime Pro Edition User Guide: Third-party Simulation for more guidelines on incorporating the generated Synopsys VCS MX simulation scripts into a top-level project simulation setup script.
Agilex® 5 FPGA no longer supports the VCS 2-step flow; only the VCS 3-step flow is supported.
