Knowledge Base Article
xmelab: *F,CUMSTS: Timescale directive missing on one or more modules.
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.1, you may see this error message while simulating the High Bandwidth Memory (HBM2) Interface Intel FPGA IP Design Example with the Cadence* Xcelium* simulator.
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 21.1, follow the steps below:
  1. Go to <example_design_path>/sim/ed_sim/sim/xcelium/
  2. Open xcelium_setup.sh with your preferred text editor
  3. Locate 'USER_DEFINED_ELAB_OPTIONS' line and add the '-timescale  1ps/1ps' option. After editing xcelium_setup.sh, the 'USER_DEFINED_ELAB_OPTIONS' line will look as follows:  USER_DEFINED_ELAB_OPTIONS="-timescale  1ps/1ps"
  4. Execute ./xcelium_setup.sh
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 21.3.
Updated 11 months ago
Version 3.0
