Knowledge Base Article
Why won’t the “refclock_status”, “out_systempll_synthlock_i” and “refclk_fgt_enabled_i” ports assert on the F-Tile Reference and System PLL Clocks IP variant?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.2, the “refclock_status”, “out_systempll_synthlock_i” and “refclk_fgt_enabled_i” ports may fail assert on the F-Tile Reference and System PLL Clocks IP variant when the “Refclk #i is active at and after device configuration” parameter is not enabled.
Resolution
There is no workaround for this problem.
This problem have been fixed in the Quartus® Prime Pro Edition Software version 24.3.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
