Knowledge Base Article
Why UART1.RTS_N and UART1.CTS are missing in exported ports on Intel® Arria® 10 HPS Dedicated I/O?
Description
Due to a problem in the Intel® Quartus® Prime Edition Software version, you cannot assign UART pin assignments below on Intel® Arria ® 10 HPS Dedicated I/O.
13:UART1:RTS_N
14:UART1:CTS_N
16:UART1:TX
17:UART1:RX
Resolution
Use alternative pin assignments below to work around this problem in the Intel® Quartus® Prime Pro/Standard Edition Software versions.
12:UART1.TX
13:UART1:RTS_N
14:UART1:CTS_N
15:UART1:RX
However, if you cannot assign the above assignment, follow the steps below.
1. Create a design on Platform Designer with UART pin assignments below on HPS Dedicated I/O, and generate RTL.
12:UART1.TX
13:UART1:RTS_N
14:UART1:CTS_N
15:UART1:RX
16:NONE
17:NONE
2. Compile the design on Quartus
3. Open hps_isw_handoff/hps.xml.
Pin 12 and 15 are updated to NONE. Pin 16 and 17 are updated to UART1.TX and UART1.RX. All bold text is updated.
<config name='i_io48_pin_mux_dedicated_io_grp.pinmux_dedicated_io_12.sel' value='10' />
<config name='i_io48_pin_mux_dedicated_io_grp.pinmux_dedicated_io_13.sel' value='13' />
<config name='i_io48_pin_mux_dedicated_io_grp.pinmux_dedicated_io_14.sel' value='13' />
<config name='i_io48_pin_mux_dedicated_io_grp.pinmux_dedicated_io_15.sel' value='10' />
<config name='i_io48_pin_mux_dedicated_io_grp.pinmux_dedicated_io_16.sel' value='13' />
<config name='i_io48_pin_mux_dedicated_io_grp.pinmux_dedicated_io_17.sel' value='13' />
<!-- Unused pin 12 -->
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.rtrim' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.input_buf_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.wk_pu_en' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.pu_slw_rt' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.pd_slw_rt' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.pu_drv_strg' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_12.pd_drv_strg' value='0' />
<!-- hps_uart1_rts_n, HPS_DEDICATED_13, NOT input, weak pull up disable, is output, Fast Slew, 1_8 -->
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.rtrim' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.input_buf_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.wk_pu_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.pu_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.pd_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.pu_drv_strg' value='8' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_13.pd_drv_strg' value='10' />
<!-- hps_uart1_cts_n, HPS_DEDICATED_14, input, weak pull up disable, Not Output, Default, 1_8 -->
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.rtrim' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.input_buf_en' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.wk_pu_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.pu_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.pd_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.pu_drv_strg' value='8' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_14.pd_drv_strg' value='10' />
<!-- Unused pin 15 -->
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.rtrim' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.input_buf_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.wk_pu_en' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.pu_slw_rt' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.pd_slw_rt' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.pu_drv_strg' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_15.pd_drv_strg' value='0' />
<!-- hps_uart1_tx, HPS_DEDICATED_16, NOT input, weak pull up disable, is output, Fast Slew, 1_8 -->
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.rtrim' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.input_buf_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.wk_pu_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.pu_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.pd_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.pu_drv_strg' value='8' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_16.pd_drv_strg' value='10' />
<!-- hps_uart1_rx, HPS_DEDICATED_17, input, weak pull up disable, Not Output, Default, 1_8 -->
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.rtrim' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.input_buf_en' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.wk_pu_en' value='0' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.pu_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.pd_slw_rt' value='1' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.pu_drv_strg' value='8' />
<config name='i_io48_pin_mux_dedicated_io_grp.configuration_dedicated_io_17.pd_drv_strg' value='10' />
This problem will be fixed in a future release of the Intel® Quartus® Prime Edition Software.
