Knowledge Base Article
Why isn’t there any PLLs usage if I compile the project with the Stratix® 10 FPGA E-tile transceiver channels ?
Description
This is an expected behaviour. You will see "Total PLLs" usage is 0 if you only instantiate Intel® Stratix® 10 FPGA E-tile transceiver channels in the design. The Stratix® 10 FPGA E-tile transceiver channel phase-locked loop (PLL) would not be counted in the total PLLs summary.
For example, if you use Stratix® 10 device 1ST280EY2F55, and instantiate four E-tile transceiver channels. After compilation, you will still see the “Total PLLs 0/64(0%)” in the flow summary of the compilation report.
Resolution
All PLLs shown in the compilation report are contributed by the Stratix® 10 IOPLL and H-tile transceiver PLLs. For Stratix® 10 device 1ST280EY2F55, the total 64 PLLs consist of 24xIOPLLs, 8xfPLLs of H-tile, 8xATX PLLs of H-tile transceiver, and 24 CDR PLLs of H-tile transceiver. Stratix® 10 FPGA E-tile transceiver channel PLLs are not counted.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 19.3.
