Knowledge Base Article
Why is there invalid data on the rx_avs interface of Serial Lite IV Intel® FPGA IP on Intel Agilex® 7 devices and Intel® Stratix® 10 devices?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.4 and earlier, you might see invalid data on the rx_avs interface of Serial Lite IV Intel® FPGA IP if you reset its link partner Serial Lite IV Intel® FPGA IP.
The following is an example waveform capture for invalid data:
- rx_avs_data will toggle, containing some random data.
- rx_avs_valid will toggle, but no sop/eop asserted when rx_avs_valid is high.
- rx_link_up will go high with unexpected random data and valid indication. rx_error shows a PCS error.
Resolution
To fix this problem, download and install the following patch:
- Intel® Quartus® Prime Pro Edition Software v21.4 Patch 0.69 for Linux (quartus-21.4-0.69-linux.run)
- Intel® Quartus® Prime Pro Edition Software v21.4 Patch 0.69 for windows (quartus-21.4-0.69-windows.exe)
- Readme for Intel® Quartus® Prime Pro Edition Software v21.4 Patch 0.69 (quartus-21.4-0.69-readme.txt)
This problem is scheduled to be fixed in a future release of Intel® Quartus® Prime Pro Edition Software.
Updated 8 months ago
Version 3.0No CommentsBe the first to comment
