Knowledge Base Article
Why is the Read Device Dummy Clock instruction unreliable when using the QUAD and DUAL I/O options on the ASMI Parallel Intel® FPGA IP?
Description
When the read_dummyclk input of the ASMI Parallel Intel® FPGA IP is asserted, the IP performs a read of the non-volatile control register of the EPCQ configuration device to determine the number of dummy cycles that are required for a fast read operation.
Due to a problem with the IP, the outputs of the FPGA are not tri-stated during the read status operation at the time when the EPCQ device should return the data. This leads to a conflict on the DATA[3..0] signals. This conflict may mean that the incorrect value is returned.
Resolution
Do not use the DUAL or QUAD I/O options available on the ASMI Parallel Intel® FPGA IP.
This problem has been resolved in the the Quartus® II software version 14.0 and onwards.
Related Articles
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
