Knowledge Base Article
Why is the on-die termination resistor for the Reference Clock pin of the Intel® Stratix® 10 E-tile device always disabled in the fitter report ?
Description
Due to a problem in the Intel® Quartus® Prime Pro Software version 19.2 and earlier, the on-die termination resistors are always disabled in the fitter report even if the assignment below is applied explicitly.
set_instance_assignment -name HSSI_PARAMETER "refclk_divider_enable_termination=enable_term" -to <refclk_pin>
Resolution
There is no workaround.
This problem is fixed beginning with the Intel® Quartus® Prime Pro Edition software version 19.3.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
