Knowledge Base Article
Why is the o_rx_pfc signal asserted incorrectly when using the F-Tile Ethernet Hard IP in 400GE mode?
Description
Due to a problem in the F-Tile Ethernet Hard IP in 400GE mode, situations can exist where the Hard IP receives back-to-back PFC frames, the 2nd PFC frame may incorrectly clear the PFC counters for unrelated queues, causing these queues to stop being back-pressured as intended. The issue only occurs when ALL of the following conditions are met:
1.) The 2nd PFC frame is sent before the quanta of the 1st PFC frame expires
2.) The Priority Enable Vector (PEV) of the 2nd PFC frame has some of the same classes enabled as the 1st PFC frame
3.) The packet arrangement on the RX MAC MII interface is such that the 2nd PFC frame’s PEV and End-of-Packet appear in the same MII clock cycle
4.) No other type of frame is sent between the two PFC frames
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.3.1.
