Knowledge Base Article
Why is the JTAG ID readout from Configuration Debugger incorrect?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 23.1 and earlier, you might see an incorrect JTAG ID from the configuration debugger tool for the device based on secure device manager (SDM) and legacy devices.
The root cause is that when the tool retrieves JTAG ID from the lookup table for the connected device, it will always take the first device in the list (including the compatible devices) as the default device for the JTAGID.
Resolution
To work around this problem, use the JTAG command to check the JTAGID:
$jtagconfig -d
Updated 4 months ago
Version 5.0
