Knowledge Base Article
Why is the Fronthaul Compression FPGA IP Example Design unable to meet timing requirements, especially with the Stratix® 10 FPGA H-Tile?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.1, you may see a timing failure when the Data Direction is set to "TX and RX" and the Compression Method is set to "BFP".
Resolution
This problem is fixed in 24.2 release of the Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0
