Knowledge Base Article
Why is the Ethernet MDIO IP unavailable in the IP Catalog and Platform Designer of Quartus® Prime Pro Edition Software version 26.1 for Agilex® 5 FPGA and Agilex® 3 FPGA designs?
Description
From Quartus® Prime Pro Edition Software versions 24.1 through 26.1, the Ethernet MDIO IP is not available in the IP Catalog for Agilex® 5 FPGA and Agilex® 3 FPGA devices because support for these device families has not been enabled for the IP.
Resolution
A patch is available to resolve this issue in Quartus® Prime Pro Edition Software version 26.1.
To install the fix:
- Download Patch 0.29 for your operating system.
- Install Patch 0.29 into your Quartus® Prime Pro Edition Software version 26.1 installation.
The patch files are available below:
- Patch 0.29 for Windows (.exe)
- Patch 0.29 for Linux (.run)
After installing the patch, the Ethernet MDIO IP will be available in the IP Catalog for Agilex® 5 FPGA and Agilex® 3 FPGA designs.
Updated 3 months ago
Version 3.0No CommentsBe the first to comment
