Knowledge Base Article
Why is the eCPRI FPGA Example Design unable to support interworking function (IWF) in the Agilex® 5 FPGA device?
Description
Due to a problem in the eCPRI FPGA IP version 3.0.2, you may find that the user has no option to generate an Example Design with the interworking functions (IWF) parameter enabled for the Agilex® 5 FPGA device.
Resolution
There is no workaround currently, and there is no plan to fix this problem.
Updated 4 months ago
Version 6.0
