Knowledge Base Article
Why is the Direct‑to‑Factory Image Pin reported as an Output?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 26.1 and earlier, you will see the compilation report identifies the Direct‑to‑Factory Image pin as an output after completing a full compilation in Quartus® Prime Pro Edition Software targeting Agilex® 7 FPGA device and Agilex® 5 FPGA device. According to the Agilex® 7 FPGA Configuration User Guide and Device Configuration User Guide: Agilex® 5 FPGAs and SoCs, this pin is defined as an input.
Resolution
This is a reporting discrepancy found in the Quartus® Prime Pro Edition Software. The Direct‑to‑Factory Image pin is correctly defined as an input. This problem is scheduled to be resolved in a future release of the Quartus® Prime Pro Edition Software.
Updated 6 months ago
