Knowledge Base Article
Why is the dangling signal with preserve_for_debug attribute not available in the Node Finder Filter with "Signal Tap: post-fitting preserved for debug."
Description
Due to a problem in the Quartus® Prime Pro Edition Software v23.2 and earlier, the dangling signal with preserve_for_debug attribute is not available in the Node Finder with Filter Signal Tap: post-fitting preserved for debug.
Resolution
To work around this problem, the user Node Finder filter without the Signal Tap prefix. For example, Post-synthesis preserved for debug or Post-Compilation.
Updated 1 month ago
Version 2.0
