Knowledge Base Article
Why is the dangling signal with perserve_for_debug attribute still optimized away after compilation?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software v22.3 and earlier, you might see the dangling signal is optimized away, although it has preserve_for_debug synthesis attribute.
Resolution
To work around this problem, connect the dangling signal to the top-level pin to avoid synthesis optimization.
This problem is fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.4.
Updated 11 months ago
Version 3.0
