Knowledge Base Article
Why is the clock not running in my design when I use the Clock Control Intel® FPGA IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2, you might see the clock which input to the Clock Control Intel® FPGA IP is not running. This problem occurs when you enable the Clock Enable feature in the Clock Control Intel® FPGA IP and drive the ena port low.
This problem only affects designs targetting Intel® Stratix® 10 or Intel Agilex® 7 devices.
Resolution
To work around this problem, set the "Clock Enable Type" in Clock Control Intel® FPGA IP to Root Level.
This problem is fixed beginning in the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 11 months ago
Version 3.0
