Knowledge Base Article
Why is SW2 missing on my Agilex® 5 FPGA E-Series 065B Modular Development Kit?
Description
Due to an issue with the revision C2 Agilex® 5 FPGA E-Series 065B Modular Development Kit carrier board, power switch SW2 is not installed.
As a result, the PCIe® 12 V or ATX 12 V power supply paths cannot be controlled. A Rev C2 Carrier board uses the PCIe® 12 V supply when the card is plugged into a server and uses the ATX power when 12 V is provided from the ATX connector. DO NOT Connect both ATX 12V and PCIe 12V powers simultaneously.
You can identify a Rev C2 board by one of the following methods:
  • Serial number range—A5EBMKPA100009 to A5EBMKPA100050
  • Absence of SW2
  • "RevC2" silkscreen marking near the PCIe edge connector
Resolution
Agilex® 5 FPGA E-Series 065B Modular Development Kit revision C3 carrier boards are corrected and have SW2 installed.
Updated 2 months ago
Version 3.0
