Knowledge Base Article
Why is PTP enabled F-Tile Ethernet FPGA Hard IP design using Quartus® Prime Pro Edition showing an error when the PTP enabled F-Tile Ethernet FPGA Hard IP design is connected to System PLL1 clock or System PLL2 clock?
Description
Due to a limitation in the Quartus® Prime Pro Edition Software, the F-Tile Ethernet FPGA Hard IP shows an error when PTP enabled design is connected to system PLL 1 clock.
This problem is seen in designs that have multiple IPs and when the IP with PTP enabled is connected to System PLL 1 clock or System PLL2 clock.
Resolution
The workaround for this limitation is to connect PTP enabled F-Tile Ethernet FPGA Hard IP to System PLL0 clock only.
Updated 6 months ago
Version 2.0
