Knowledge Base Article
Why is my Nios® II Ethernet Standard Design Example with NicheStack TCP/IP not working in the Intel® Quartus® Prime Standard Software version 21.1?
Description
The deliverable for NicheStack TCP/IP Stack used in Nios® II applications is discontinued starting with Intel® Quartus® Prime Standard Software version 21.1.
This includes the following:
  1. Removal of software/driver packages from Intel® Quartus® Prime Software
  • InterNiche NicheStack software package– (altera_iniche)
  • Triple Speed Ethernet (TSE) UCOSII driver – (triple_speed_ethernet_driver_ucosii_iniche), (altera_eth_tse_driver_ucosii_iniche)
  • LAN91C111 UCOSII driver – (altera_avalon_lan91c111_ucosii_driver)
  1. Removal of Simple Socket Server and Webserver template from Nios® II Embedded Design Suites
  2. Nios® II remote debug design example is not supported
Resolution
Intel recommends users to port over designs with NicheStack to the new TCP-IP stack when it is made available.
Reference
For more information on NicheStack support and licensing, please refer to Using NicheStack TCP/IP Stack – Nios® II Edition
Updated 11 months ago
Version 3.0
