Knowledge Base Article
Why is my calculated value for Tx or Rx UI incorrect when using the scripts found in the design examples for Precision Time Protocol (PTP) variants of the F-Tile Ethernet Intel® FPGA Hard IP?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.2, the scripts provided in the F-Tile Ethernet Intel® FPGA Hard IP Designs with Precision Time Protocol (PTP) can show incorrect Tx or Rx UI values.
Resolution
To work around this problem, perform the following steps:
- Open the PTP firmware script located at <generated example design folder>/hardware_test_design/hwtest/altera/ptp/ptp_fw.tcl
- Find and replace the following lines of code:
- FROM set tx_tam_cnt [format 0x%X [expr [expr $rd_data & 0x3FFF0000] >> 16]]
- TO set tx_tam_cnt [format 0x%X [expr [expr $rd_data & 0x7FFF0000] >> 16]]
- FROM set rx_tam_cnt [format 0x%X [expr [expr $rd_data & 0x3FFF0000] >> 16]]
- TO set rx_tam_cnt [format 0x%X [expr [expr $rd_data & 0x7FFF0000] >> 16]
- FROM set tx_tam_cnt_delta_max 32767
- TO set tx_tam_cnt_delta_max 32768
- FROM set rx_tam_cnt_delta_max 32767
- TO set rx_tam_cnt_delta_max 32768
Save the file
This problem has been fixed starting in version 22.3 of the Intel® Quartus® Prime Pro Edition Software.
Updated 2 months ago
