Knowledge Base Article
Why Intel® Stratix®10 FPGA EMIF Debug Toolkit showing a wrong value at the IP Rate parameter in the Memory Configuration tab?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 21.4, the EMIF Debug Toolkit is showing a wrong value at the IP Rate parameter.
This problem occurs because the EMIF Debug Toolkit refers to the PHY Rate instead of the IP Rate.
Resolution
This problem has been fixed starting with the Intel® Quartus® Prime Pro Edition Software version 22.3.
Updated 2 months ago
Version 2.0
