Knowledge Base Article
Why has the MegaWizard Plug-In Manager failed to launch?
Description
Due to a problem in Intel® Quartus® Prime Standard Software version 17.0,  the following error message will be displayed when launching the DDR3 SDRAM Controller with UniPHY Intel® FPGA IP.
Failed to launch MegaWizard Plugin Manager: DDR3 SDRAM Controller with UniPHY 17.0 could not be found in the specified library paths.
Resolution
A patch is available to fix this problem for the Intel® Quartus® Prime Standard Software version 17.0.2.
Download and install Patch 2.02 from the appropriate link below.
Download the patch Intel® Quartus® Prime Standard Edition version 17.0.2 Patch 2.02 for Windows* (.exe)
Download the patch Intel® Quartus® Prime Standard Edition version 17.0.2 Patch 2.02 for Linux* (.run)
Download the Readme for Intel® Quartus® Prime Standard Edition version 17.0.2 Patch 2.02 (.txt)
Additional Information
This problem is fixed starting with the Intel® Quartus® Prime Standard Edition software version 17.1.
Updated 8 months ago
Version 3.0
