Knowledge Base Article
Why doesn't the F-Tile Ethernet Intel® FPGA Hard IP with PTP enabled support the Aldec* Riviera* VHDL simulator in the Intel® Quartus® Prime Pro Edition Software version 22.4 and earlier?
Description
Due to a problem in the Intel® Quartus® Prime Pro Edition Software version 22.4 and earlier, the F-Tile Ethernet Intel® FPGA Hard IP with PTP enabled doesn't support the Aldec* Riviera* VHDL simulator.
You might get stuck waiting for TX/RX PTP Offset Data Valid assertion when simulating with the Aldec* Riviera* VHDL simulator.
Resolution
There is no workaround for this problem.
This problem is scheduled to be fixed in a future release of the Intel® Quartus® Prime Pro Edition Software.
Updated 11 months ago
Version 3.0No CommentsBe the first to comment
