Knowledge Base Article
Why does Vendor Authorized Boot (VAB) certificate authentication failed in SDM?
Description
During the Second-Stage Bootloader (SSBL), you may encounter an intermittent timeout while transferring the initial 32‑word block of the VAB certificate command
Error message displayed:
#ret = 0x000007ff, resp = 0x00000000, resp_len = 1
#VAB certificate authentication failed in SDM
#### ERROR ### Please RESET the board ###
Resolution
To avoid this problem, upgrade the socfpga_v2.12.1 (socfpga_mailbox.c)
An ATF patch for socfpga_v2.12.1 is available to fix this problem :
Download and install patch mbox.patch from the attachment below.
This problem is scheduled to be resolved in a future ATF released
Updated 7 months ago
Version 2.0
