Knowledge Base Article
Why does the TX, RX and CSR reset not work correctly when using the Intel® Stratix® 10 FPAG E-Tile Hard IP for Ethernet Intel® FPGA IP Core?
Description
When using the Intel® Stratix® 10 FPGA E-Tile Hard IP for Ethernet Intel® FPGA IP Core, the TX, RX and CSR resets do not work correctly due to an error in the file alt_ehipc3_sl_soft.sv, the following signals are connected as below:
          .soft_tx_rst_in            (i_sl_soft_csr_rst),
          .soft_rx_rst_in            (i_sl_soft_tx_rst),
          .soft_csr_rst_in          (i_sl_soft_rx_rst),
This has been confirmed as a bug.
Resolution
To work around this problem use the signals in the following manner:
1.  To reset the soft_tx-rst_in use i_sl_soft_csr_rst
2. To reset the soft_rx_rst_in use i_sl_soft_tx_rst
3. To reset the soft_csr_rst_in use i_sl_soft_rx_rst
This problem has been fixed starting in Intel® Quartus® Prime software version 18.0 update 1.
Updated 1 month ago
Version 2.0
