Knowledge Base Article
Why does the Triple-Speed Ethernet FPGA IP for Agilex® 5 FPGA devices, when configured with the 'Transceiver type' set to 'LVDS I/O', result in a fitter error for the Quartus® Prime Pro Edition software version 24.3.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 24.3.1, when compiling the design, you may see a fitter error indicating that the fitter cannot place 1 BYTE because there is no routing connectivity between the BYTE and the destination pin.
This problem occurs because the IP submodule Agilex® 5 LVDS SERDES IP requires specific pin parameter settings based on the intended pin lock. However, these settings are not currently exposed through the Triple-Speed Ethernet IP GUI for the Agilex® 5 FPGA devices, which prevents the Quartus® Prime software from correctly routing the signals to the designated I/O pins.
Resolution
A patch is available to fix this problem for the Quartus® Prime Pro Edition software version 24.3.1.
Download and install patch 1.18 from the below.
Please follow the User guide instructions for updating the PIN parameter settings.
Please contact your local Sales representative or submit a request through the Support page for further support.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
