Knowledge Base Article
Why Does the Simplex RX/TX Design Example Fail During HSSI Support Logic Generation with a QHIP_IP_PROPERTY Case Sensitivity Error in F-Tile JESD204B IP?
Description
Due to a problem in Quartus® Prime Pro Edition Design Software Version 25.3, the F-Tile JESD204B IP Simplex RX/TX example design may fail with the following error in compilation:
"Cannot find QHIP_IP_PROPERTY tile_ip_sip_instances with value …..."
Resolution
To work around this compilation error, manually remove the QHIP_IP_PROPERTY assignment from the .qip file in the Design Example folder.
Steps:
- Navigate to the following path in the Design Example directory:
intel_jesd204b_gts_<data path>/example_design/ed_synth/ip/jesd_gts_ss<data path>/jesd_gts_ss_<data path>intel_jesd<data path>/ - Open the QIP file:
jesd_gts_ss_<data path>intel_jesd<data path>.qip - Locate and remove the line containing the QHIP_IP_PROPERTY assignment.
- Save the file and retry the compilation.
This issue is fixed in Quartus® Prime Pro Edition Design Software Version 25.3.1.
Updated 5 months ago
