Knowledge Base Article
Why does the second AN/LT port fail in the Ethernet Toolkit when using the F-Tile Ethernet Hard IP in the Quartus® Prime Pro Edition Software version 24.3.1?
Description
Due to a problem in the Quartus® Prime Pro Edition Software Ethernet Toolkit, if there are multiple AN/LT ports on the F-Tile Ethernet Hard IP, the second port shows incorrect status.
This problem is limited to the Ethernet Toolkit; direct access to the respective AN/LT registers by user logic is not affected.
Resolution
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 3 months ago
Version 6.0
