Knowledge Base Article
Why does the SDM experience a hang when performing back-to-back reconfigurations on Agilex™ FPGA devices?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 22.4 and later, the SDM may hang during back-to-back reconfiguration. This issue can occur in all configuration modes.
The probability of occurrence is very low, as it depends on several factors such as design seed, utilization, data rate, configuration source, compression ratio, and others.
When this issue occurs:
  • In AVST mode, AVST_READY is deasserted (=low) in the middle of reconfiguration and remains low.
  • nSTATUS is not deasserted (=low), therefore, no configuration error is flagged.
  • CONFIG_STATUS continues to indicate that configuration is ongoing, with no error detected.
This issue may affect Agilex™ 3, 5, and 7 FPGA devices.
Resolution
To work around this problem:
  • Perform reconfiguration via JTAG, which recovers from the issue.
This problem is planned to be fixed in Quartus® Prime Pro Edition Software version 25.1.1.
The fix increases the configuration time maximum up to 1%.
For existing versions, download and install the corresponding patch to fix the problem:
Updated 8 months ago
Version 3.0
