Knowledge Base Article
Why does the R-tile AXI Streaming IP for PCI Express* fail compilation in the Quartus® Prime Pro Edition software version 25.1?
Description
Due to a problem in the 25.1 version of the R-tile AXI Streaming IP for PCI Express*, compilation will fail during the fitter stage when pin locations are assigned with the following or similar error(s):
Error(171016): Can't place node "hip_serial_tx_n_out0~pad" -- illegal location assignment
Resolution
To work around this problem, remove all the location assignments for the AXI Streaming IP for PCI Express* in the Assignment Editor or by editing the project .QSF file, and recompile the design.
The problem has been fixed starting with Quartus® Prime Pro Edition software version 25.1.1.
Updated 5 months ago
Version 5.0
