Knowledge Base Article
Why does the R-Tile AXI Multichannel DMA IP for PCI Express* AXI-S Packet Generate/Check Example Design generation fail with Enable User FLR is selected?
Description
Due to a problem in the Quartus® Prime Pro Edition Software versions 25.3 and later, Example Design generation fails for the R-Tile AXI Multichannel DMA IP for PCI Express* when:
  • AXI-S Packet Generate/Check mode is selected
  • Enable User FLR option is selected under the PCIe Settings --> MCDMA Settings tab.
The problem is observed a few minutes after clicking the Generate Example Design button. Quartus® Prime Pro Edition Software reports an error in the Generate Example Design Completed window and the Example Design is not generated successfully.
An example of the message observed in the Generate Example Design Completed window is shown below:
Error: pcie_axi_mcdma_0: Fail .qsys synthesis generation
Error: pcie_axi_mcdma_0: Unable to generated HDL Files for the system .qsys
Error: Failed to generate example design example_design to: <path>
Generate Example Design: completed with errors.
This problem applies only to the AXI-S Packet Generator/Checker variant of the Example Design.
The AXI Multichannel DMA IP itself can still be generated successfully when the Enable User FLR option is selected.
Resolution
To work around this problem, do not select the Enable User FLR option when generating the R-Tile AXI Multichannel DMA IP for PCI Express* AXI-S Packet Generate/Check Example Design.
There is currently no other workaround for Quartus® Prime Pro Edition Software versions 25.3 and later.
This problem is planned to be fixed in a future release of the Quartus® Prime Pro Edition Software.
Updated 4 months ago
Version 3.0
