Knowledge Base Article
Why does the R-Tile Avalon® Streaming FPGA IP for PCI Express* Design Example simulation fail when using the Questa*-Altera® FPGA Edition Software?
Description
Due to a problem in the Quartus® Prime Pro Edition Software version 25.1 and later, simulation of the R-Tile Avalon® Streaming FPGA IP for PCI Express* Design Example with PIPE mode enabled will fail when using the Questa*-Altera® FPGA Edition Software.
Refer to the R-Tile Avalon® Streaming FPGA IP for PCI Express* Design Example User Guide
Version Found: 25.1
Resolution
To work around this issue, do one of the following:
- Generate the R-Tile Avalon® Streaming FPGA IP for PCI Express* Design Example with PIPE Mode Disabled when simulating with the Questa*-Altera® FPGA Edition Software
or,
- Use full version of the Questasim* Software to simulate the R-Tile Avalon® Streaming FPGA IP for PCI Express* Design Example with PIPE Mode enabled.
A patch is NOT available to fix this issue.
Updated 4 months ago
Version 5.0No CommentsBe the first to comment
