Knowledge Base Article
Why does the Quartus® Prime Pro Edition Software version 26.3 and earlier still allow horizontal NoC links on Agilex® 7 FPGA M-Series non-HBM devices (AGMA, AGMB)?
Description
In the Agilex® 7 FPGA M-Series non-HBM device (Ordering Part Numbers starting with AGMA and AGMB), horizontal Network-on-Chip (NoC) links, left-to-right and right-to-left (RL0, RL1, LR0, LR1), are restricted from use in customer designs. Due to a problem, the Quartus® Prime Pro Edition Software version 26.3 and earlier does not enforce this restriction. A design that uses these links can still pass compilation in these versions, but a passing compilation does not mean the links can be used for production. The software restriction is enabled from the Quartus® Prime Pro Edition Software version 26.3.1 onwards, and prevents the use of these links except for HPS EMIF, as described below.
Your design is using horizontal NoC links if either of the following is true:
  • In the External Memory Interfaces (EMIF) FPGA IP, the Sideband Access Mode parameter is set to NOC.
  • One NoC initiators (INIU) accessing one NoC target (TNIU) also uses a horizontal NoC link when that is not its local (directly connected, vertical) target. The same applies when several NoC initiators share one NoC target, or one NoC initiator accesses several NoC targets.
This restriction does not apply to:
  • Agilex® 7 FPGA M-Series HBM devices (OPNs starting with AGME, AGMF, AGMG, and AGMH). Horizontal NoC links remain supported on these devices.
  • HPS EMIF interfaces in I/O banks 3C and 3D. HPS EMIF continues to use the horizontal NoC links to access I/O banks 3C and 3D, and no design change is required.
Resolution
To work around this problem in the Quartus® Prime Pro Edition Software version 26.3 and earlier, update the EMIF FPGA IP and the NoC assignments so that the design uses only vertical links:
  1. This applies when Mainband Access Mode is set to NOC. In the EMIF FPGA IP PHY configuration, set Sideband Access Mode to Fabric Direct. Do not select NOC. You can keep Mainband Access Mode set to NOC when each NoC initiator (INIU) uses a one-to-one vertical link to its local NoC target (TNIU).
  2. If a NoC initiator reaches a NoC target that is not its local vertical target, use one of the following:
    1. Change the assignment to one-to-one vertical links.
    2. If your design needs several AXI4 managers to share one memory interface, one AXI4 manager to access several memory interfaces, or both, move the arbitration into the FPGA fabric. Use soft logic to arbitrate between the managers and to route each request so that every NoC target is accessed only through its local NoC initiator.
    3. Access the EMIF directly from the fabric (EMIF bypass mode).
  3. Regenerate the IP and recompile the design.
A patch is available to fix this problem for the Quartus® Prime Pro Edition Software version 26.3. Download and install patch 0.06 in attachment below.
  • Quartus® Prime Pro Edition Software version 26.3 Patch 0.06 Windows
    • quartus-26.3-0.06-windows.zip
  • Quartus® Prime Pro Edition Software version 26.3 Patch 0.06 Linux
    • quartus-26.3-0.06-linux.zip
  • Quartus® Prime Pro Edition Software version 26.3 Patch 0.06 Readme
    • quartus-26.3-0.06-readme.zip
This problem is fixed starting from Quartus® Prime Pro Edition Software version 26.3.1.
Additional Information
On releases before version 26.3, no patch is available. Apply the same design change, and place each initiator bridgeso that the INIU uses the correct vertical link to talk to its target (TNIU).
Starting with the Quartus® Prime Pro Edition Software version 26.3.1, the same restriction is in the software:
  • The EMIF FPGA IP removes the NOC option for Sideband Access Mode on non-HBM devices. Only Fabric Direct is available.
  • The Fitter reports an error if the design uses horizontal NoC links on these devices.
Related Articles
Updated 3 hours ago
Version 2.0
