Knowledge Base Article
Why does the Quartus® Prime Pro Edition Software report that no IOPLL is available when placing the Low Latency E-Tile 40G Ethernet FPGA IP in an HPS shared GPIO Bank?
Description
Due to a clocking limitation of HPS Shared GPIO Bank, the Low Latency E-Tile 40G Ethernet FPGA IP cannot be placed in an HPS Shared GPIO Bank when a design targets Agilex® 7 FPGA F-Series. If the IP placement requires its IOPLLs to use an HPS Shared GPIO Bank, the fitter may report that no IOPLL IP is available and compilation may fail during the fitter stage.
The Low Latency E-Tile 40G Ethernet FPGA IP uses IOPLL IPs configured in Normal Compensation mode. However, the IOPLL resources in an HPS Shared GPIO Bank support Direct Compensation mode only. Consequently, the fitter cannot legally place the IOPLLs in the Low Latency E-tile 40G Ethernet FPGA IP in an HPS Shared GPIO Bank.
Resolution
To avoid this problem, place the Low Latency E-Tile 40G Ethernet FPGA IP in a supported non-HPS Shared GPIO Bank.
Updated 2 months ago
Version 3.0
