Knowledge Base Article
Why does the Quartus® fail Design Analysis when the 1G/2.5G/5G/10G Multirate Ethernet PHY IP and the F-Tile 1000BASE-KX Ethernet PHY IP are used in the same design?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 26.1, Design Analysis might fail when a design targeting Agilex® F-Tile devices instantiates both of the following IP cores in the same project:
  • 1G/2.5G/5G/10G Multirate Ethernet PHY IP (alt_mge_phy)
  • F-Tile 1000BASE-KX Ethernet PHY IP (intel_mge_phy_f)
Both IP cores include an RTL module named alt_mge_phy_pcs. The F-Tile 1000BASE-KX Ethernet PHY version of alt_mge_phy_pcs declares an additional parameter (ENABLE_GMII_ADAPTER) that is not present in the Multirate Ethernet PHY version. When Quartus elaborates the design, the Multirate Ethernet PHY definition of alt_mge_phy_pcs can be used for both instances, which causes a parameter mismatch and compilation failure for the F-Tile 1000BASE-KX Ethernet PHY IP.
Using either IP alone does not trigger this failure.
Resolution
A patch (26.1 patch 0.28) is available to fix this problem for the Quartus Prime Pro Edition Software version 26.1. To request the patch, contact your local Altera support representative.
This problem is scheduled to be resolved in a future release of the Quartus Prime Pro Edition Software.
Updated 3 months ago
Version 2.0
