Knowledge Base Article
Why does the Nios® V/g processor return inaccurate floating-point calculation results when the Floating-Point Unit is enabled?
Description
Due to a problem in the Quartus® Prime Standard Edition Software version 24.1, the Nios® V/g processor might return inaccurate floating-point calculation results when the Floating-Point Unit (FPU) is enabled.
This problem is found in MAX® 10 FPGA devices only. Other Altera® FPGA devices are not affected.
This is because there is a problem in the FPU module, which generates spurious signals affecting the calculation results.
Resolution
A patch is available to fix this problem for the Quartus® Prime Standard Edition Software version 24.1.
Download and install patch 0.03 from the following links:
The problem has been fixed starting with Quartus® Prime Standard Edition software version 25.3.
Updated 3 months ago
Version 7.0
