Knowledge Base Article
Why does the Multi-Channel DMA Intel® FPGA IP for PCI Express Design Example targeting the Intel Agilex® 7 FPGA R-Tile devices fail in hardware testing when it is compiled with the Intel® Quartus® Prime Pro Edition Software version 22.4?
Description
After programming the Multi-Channel DMA Intel® FPGA IP for PCI Express Design Example targetting the Intel Agilex® 7 FPGA R-Tile devices A0 or B0 die revision, the PIO tests will fail, and the DMA tests report queue reset failures.
DK-DEV-AGI027RES : AGIB027R29A1E2VR0 = A0 die revision.
DK-DEV-AGI027R1BES : AGIB027R29A1E2VR3 = B0 die revision.
Resolution
A patch is available to fix this problem in the Intel® Quartus® Prime Pro Edition Software version 22.4
Regenerate and recompile the test design after installing the patch.
- Intel® Quartus® Prime Pro Edition Software v22.4 Patch 0.02 for Linux (.run)
- Intel® Quartus® Prime Pro Edition Software v22.4 Patch 0.02 for Windows (.exe)
- Readme for Intel® Quartus® Prime Pro Edition Software v22.4 Patch 0.02 (.txt)
This problem was fixed in Intel® Quartus® Prime Pro Edition Software version 23.1
Updated 8 months ago
Version 4.0No CommentsBe the first to comment
