Knowledge Base Article
Why does the maximum observed channel-to-channel skew exceed 2 UI + 125 ps in an E-Tile transceiver under NRZ mode, even when TX PMA bonding is enabled?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3.1 and earlier, you may observe channel-to-channel skew exceeds 2 UI + 125 ps in E-Tile transceivers under NRZ mode even when TX PMA bonding is enabled.
Resolution
There is no workaround currently, and there is no plan to fix this problem.
Updated 7 months ago
Version 3.0No CommentsBe the first to comment
