Knowledge Base Article
Why does the link take long to come up for GTS Ethernet Hard IP with auto-negotiation and link training (AN/LT) multirate designs?
Description
Due to a problem in the Quartus® Prime Pro Edition software version 25.3, you may see link down problem for GTS Ethernet Hard IP with auto-negotiation and link training (AN/LT) multirate designs.
This problem happens when interop of 25G KR-FEC MRIP (MultiRate IP) design with 25G no-FEC SRIP (SingleRate IP) design variant.
Resolution
To work around this problem in the Quartus® Prime Pro Edition software version 25.3, set ‘enable_consortium_next_page_send’ to 0 in the ANLT CSR register to disable the cons next page.
| Address | Bit | SW Access | Name | Description |
| 0x300 | 8 | RW | enable_consortium_next_page_send |
Send the Consortium standard next pages immediately after the base page. If User next pages are enabled, consortium pages will be sent after the last user's next page. |
This problem is fixed beginning with the Quartus Prime Pro Edition software version 25.3.1.
