Knowledge Base Article
Why does the Interlaken (2nd Generation) Intel® FPGA IP Design Example fail to work when targetting the Intel® Stratix® 10 TX Transceiver Signal Integrity Development Kit?
Description
The Interlaken (2nd Generation) Intel® FPGA IP Design Example will fail in hardware when "Select Board" parameter is set to "Intel® Stratix® 10 TX Signal Integrity Development Kit -E-tile". The hardware test will fail with the symptom of word_locked and sync_locked signals not being asserted.
This problem is due to incorrect location assignments in the auto-generated design example Intel® Quartus® Settings File (QSF).
Resolution
To work around this problem in the Intel® Quartus® Prime Pro Edition Software version 20.4 and earlier, manually change the following QSF assignments when targetting the Intel® Stratix® 10 TX Signal Integrity Development Kit - E-Tile.
For Intel® Stratix 10® TX Signal Integrity Development Kit, E-Tile NRZ Configurations:
Signal NameAssignment in v20.4 and earlierCorrect Assignment
pll_ref_clk[0]PIN_AB37PIN_AN40
refclk_preserve_bti_ch0PIN_AN40PIN_BC18
refclk_preserve_bti_ch1PIN_AB41PIN_AB41
refclk_preserve_bti_ch2/pll_ref_clk[1]PIN_AB14PIN_AN42
refclk_preserve_bti_ch3PIN_AN15PIN_AN15
refclk_preserve_bti_ch4PIN_BC18PIN_AB14
tx_pin[0]PIN_R51PIN_AW51
rx_pin[0]PIN_P48PIN_AW45
tx_pin[1]PIN_N51PIN_AV54
rx_pin[1]PIN_K48PIN_AV48
tx_pin[2]PIN_G51PIN_AU51
rx_pin[2]PIN_N45PIN_AU45
tx_pin[3]PIN_D54PIN_AT54
rx_pin[3]PIN_E45PIN_AT48
tx_pin[4]PIN_L51PIN_AL51
rx_pin[4]PIN_F48PIN_AL45
tx_pin[5]PIN_J51PIN_AK54
rx_pin[5]PIN_J45PIN_AK48
tx_pin[6]PIN_C45PIN_AJ51
rx_pin[6]PIN_K42PIN_AJ45
tx_pin[7]PIN_D42PIN_AH54
rx_pin[7]PIN_D36PIN_AH48
tx_pin[8]PIN_C51PIN_AG51
rx_pin[8]PIN_E39PIN_AG45
tx_pin[9]PIN_D48PIN_AF54
rx_pin[9]PIN_H42PIN_AF48
tx_pin[10]PIN_C39PIN_AE51
rx_pin[10]PIN_H36PIN_AE45
tx_pin[11]PIN_B36PIN_AD54
rx_pin[11]PIN_C33PIN_AD48
For Intel® Stratix 10® TX Signal Integrity Development Kit, E-Tile PAM4 Configurations:
pll_ref_clk[0]PIN_AB12PIN_AN40
tx_pin[0]PIN_R4PIN_AW51
tx_pin_n[0]PIN_R5PIN_AW50
rx_pin[0]PIN_P7PIN_AW45
rx_pin_n[0]PIN_P8PIN_AW44
tx_pin[1]PIN_P1PIN_AV54
tx_pin_n[1]PIN_P2PIN_AV53
rx_pin[1]PIN_M7PIN_AV48
rx_pin_n[1]PIN_M8PIN_AV47
tx_pin[2]PIN_N4PIN_AU51
tx_pin_n[2]PIN_N5PIN_AU50
rx_pin[2]PIN_K7PIN_AU45
rx_pin_n[2]PIN_K8PIN_AU44
tx_pin[3]PIN_M1PIN_AT54
tx_pin_n[3]PIN_M2PIN_AT53
rx_pin[3]PIN_H7PIN_AT48
rx_pin_n[3]PIN_H8PIN_AT47
tx_pin[4]PIN_G4PIN_AL51
tx_pin_n[4]PIN_G5PIN_AL50
rx_pin[4]PIN_N10PIN_AL45
rx_pin_n[4]PIN_N11PIN_AL44
tx_pin[5]PIN_F1PIN_AK54
tx_pin_n[5]PIN_F2PIN_AK53
rx_pin[5]PIN_R10PIN_AK48
rx_pin_n[5]PIN_R11PIN_AK47
tx_pin[6]PIN_D1PIN_AJ51
tx_pin_n[6]PIN_D2PIN_AJ50
rx_pin[6]PIN_E10PIN_AJ45
rx_pin_n[6]PIN_E11PIN_AJ44
tx_pin[7]PIN_E4PIN_AH54
tx_pin_n[7]PIN_E5PIN_AH53
rx_pin[7]PIN_F13PIN_AH48
rx_pin_n[7]PIN_F14PIN_AH47
tx_pin[8]PIN_C10PIN_AG51
tx_pin_n[8]PIN_C11PIN_AG50
rx_pin[8]PIN_K13PIN_AG45
rx_pin_n[8]PIN_K14PIN_AG44
tx_pin[9]PIN_A10PIN_AF54
tx_pin_n[9]PIN_A11PIN_AF53
rx_pin[9]PIN_L16PIN_AF48
rx_pin_n[9]PIN_L17PIN_AF47
tx_pin[10]PIN_D13PIN_AE51
tx_pin_n[10]PIN_D14PIN_AE50
rx_pin[10]PIN_D19PIN_AE45
rx_pin_n[10]PIN_D20PIN_AE44
tx_pin[11]PIN_B13PIN_AD54
tx_pin_n[11]PIN_B14PIN_AD53
rx_pin[11]PIN_F19PIN_AD48
rx_pin_n[11]PIN_F20PIN_AD47
This problem has been fixed starting in version 21.1 of the Intel® Quartus® Prime Pro Software.
Updated 1 month ago
Version 2.0
